I have a few dvds that wont play in my PC. i tells me to check the region.
Anyone know how to do this or a program that can help?
thanks
Search the guides and glossary. You'll get a helpful answer from them much more quickly than by asking in forums.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Look at the bottom of the back cover of the movie. Usually you will find the region there
DVD Decrypter will tell you the region plus it will let you rip them even if for example your DVD Rom/Burner is set to region one but the discs are region two etc.
Once ripped they are region free and can be played with any software DVD player such as PowerDVD or WinDVD etc.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 11:49 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
