I have avi files of an 80's TV show that I am attempting to burn onto DVD's.
I tested the avi's for bad frames and none were found.
I have extracted the audio with GoldWave, cleaned it up, and saved it as a 48,000hz 1536kbps wav file. The video was resized to 352*240 mpeg2.
After burning onto DVD, the audio is out of sync. Most of the references to this that I have been able to find have to do with bad frames. Is there anyway this can be corrected?
Google is your Friend
Check the actual video length in gspot.
Extract the audio in virtualdub or goldwave.
Check the actual audio length.
Open audio in Goldwave/SoundForge/Audacity, and expand/contract audio to match video length exactly.
Remux/author/burn.
If the audio is still out of sync, then there is either a portion of audio missing, or a portion of video missing, or a section of "dead air" in the audio (usually right at the beginning).
Remove one or two seconds (however much you think it's out), then expand the remainder to macth the video, or add some dead air at the beginning, then contract to match video.
It's not an exact science, and there's probably 200 guides telling you how to sync video to audio, but every single file is different, so what works on one, may never work on any other.Cheers, Jim
My DVDLab Guides -
OK, the extracted audio is the same length as video, BUT, it's still out of sync. (been there done that).
If audio is BEHIND the video, then you need to cut a bit of audio and stretch it to fit video.
If audio is AHEAD the video, you need to add some dead air, then shrink it to fit video.Cheers, Jim
My DVDLab Guides
Audio Sync Issues!!!!
By earthXDust in forum EditingReplies: 3Last Post: 29th May 2011, 23:23 -
audio sync issues.................
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 16:48 -
Audio Sync Issues From AVI
By tyders in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2009, 09:36 -
Audio sync issues
By andy99 in forum EditingReplies: 7Last Post: 16th Sep 2008, 22:47 -
Audio Sync Issues
By Pinata in forum DVD RippingReplies: 2Last Post: 28th Jan 2008, 08:38
