HI all,
I have heard about frameserving and i'm not quite sure what it is. Here's my situation. I have a dance recital that i did on Premeire. It's 2 hours and 20 min. I will be doing dolby digital encoding to lessen the amount of space to use. My concern is that I don't have enough drive space to make a new AVI like I usually do to encode. Someone told me that I don't have to do it if I have premiere. I have tmpgenc but I am going to try cinemacraft which I have a copy of...i do't know about avisynth or some of the other tools because tmpgenc never required it. If anyone out there can help me it would be greatly appreciated. I have searched the forums but can't find any other topic with my exact situation.
Marc
Is there a guide for CCE? That's what i am going to use...doing a 3 pass vbr.
Marc -
I believe you can frameserve with Virtualdub to CCE the same way. Otherwise you'll have to use Avisynth. You'll have to search for Avisynth guides yourself unless someone else is nice enough to post a link. My knowledge of it is fairly limited. I cheat and use Aviscript.
Frameserving is a great way to avoid the creation of large (and time consuming) intermediary files.
Instead of creating an actual intermediary file, the frameserving process creates a "dummy avi." Whatever application you are using to read that avi is (hopefully) clueless that it isn't operating on an actual avi file. The frameserving application delivers up the frames as they are requested.
This is really useful when you want to, for example, create an MPEG file from an AVI that you have captured. However, if the AVI needs to be edited, filters applied, etc, NORMALLY you would end up saving to a new avi file.
for example (using virtual dub):
capture AVI file
edit avi file and apply filters using Virtual Dub
Save to disk
Open saved avi in CCE, Main Concept, TMPG (etc) and produce your MPEG2 file.
With frameserving:
capture AVI
edit avi and apply filters in Virtual Dub
start the frameserver process in virtual dub and create a "dummy" avi file
Open dummy avi file in CCE, Main Concept, TMPG (etc) and produce your MPEG 2 file.
The big advantage of the latter is twofold:
1) No diskspace used for the intermediate, edited AVI file.
2) No time-consuming write to disk of the intermediate AVI.
The disadvantage is that you never really have the edited avi file. If for some reason you would actually need it, it doesn't really exist. You would have to go back and create it again.
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
Reversing PAL speedup and frameserving
By Ennio in forum Video ConversionReplies: 23Last Post: 28th Jan 2010, 16:28 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31
