Results 1 to 30 of 35
  1. Video Restorer lordsmurf's Avatar
    Need I say more?
    - Program crashes on itself at start. Gives gibberish reason.
    - No preview windows.
    - Crashes on exit. So no saving of settings.
    - MC forums are ghost town. Lots of unanswered questions.
    - Runs SLLOOOWWWWW. Horrible.
    Two systems, three cards tried.
    Crap like this should still be in R&D, not for sale.
    Anybody else having bad luck with this software?
  2. I see a Tivo in your future
  3. I'll post the good luck I had with the latest version (1.1 i think) Captured a 2 hours VHS animated movie (The Maxx) setting were 1/2 D1 MPEG-2, with 48KHz audio. No dropped frames, no bugs, no hangs, no nothing. You can see my system specs in my details.
    Produced a pretty nice picture, good enough for me, anyway.
    btw, i used your guides for capturing, lordsmurf, they're awesome, good work on those!!!
    Mar 2004
    Have had some problems with crashing... I assumed that it was because you cannot disable the preview in "vcr" mode (bad thing). A cheepo ATI 128m 9600se (as apposed to MOBO video) seems to have solve that problem but my 1.8 P4 cap. machine still doesn't have the speed to get good results at dvd spec. encode.... When I gave it a spin on the 3.2 machine and it performed quite well.
    Other problems:
    a. Seems to switch to PAL every time I restart
    b. Does not have a 720x480 setting in "custom mpeg2"
    c. Cannot disable preview (as mentioned)
    d. timer not dependible
    I'm doing all my caps from firewire BTW.... so no comment on card compatibility...
    So, I thought I'd get a mainconcept mpeg encoder on the cheap but it is kinda trash... Needs more development, yes.
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    I tried the first version that was released and I was thoroughly unimpressed. It worked fine but sorely lacked some of the features of ATI MMC.
  6. I downloaded the demo last night. I wanted to try it with my PVR 250 Card but it didn't work. It worked with my ATI Card but I prefer to use ATI's MMC program with my ATI Card so I uninstalled it. Have you tried Beyond TV or SageTV?
    My goal for this software was simple: inexpensive option for those that want MPEG2 capture but do not have ATI/Hauppauge cards.
    I use ATI MMC for my ATI card.
    This is one of those things I'm trying for the sake of my site, try to keep it developed and up to date. PowerVCR II is the closest I can find to a good MPEG2 capture program (aside from the higher-priced CPU-demanding MC 1.4), and it's not perfect. I halted that guide for a while because results varied so much.
    I thought MC could step up to the plate, but they're just another A-Rod to me.
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Lordsmurf,
    Not sure if this works with other cards or fits your requirments but Leadtek's PVR apparently doesn't require a previous installation. It can capture directly to MPEG but again I'm not sure if that is dependant on the capture card. If I remember correctly it recognized my ATI card. Doesn't require registration or anything, just a straight DL.
    http://www.leadtek.com.tw/support/download.asp?pronameid=292
  9. Member vhelp's Avatar
    Mar 2001
    New York
    @ lordsmurf,
    Can you tell me where to get the MC PVR software app ??
    I have the demo version of MC 1.4.2 working, (though I don't like the
    quality I have gotten with it so far vs. what TMPG can give me, which is MUCH
    better the MC, unless I"m doing something wrong)
    I'd like to trie this PVR w/ my Winfast TV-2000 XP card (WDM)
    Thanks,
    -vhelp
    Mar 2004
    vhelp - http://www.mainconcept.com/pvr.shtml
    Mr. lordsmurf - you discribed my needs to a T. Non-ATI user looking for inexpensive mpeg2 software cap.
    I think the long and short of it is that you need a robust processor to pull it off.... For full 720x480 mpeg2 - "dvd ready" at least... Like I said my new 3.2 P4 previewed and encoded quite well with this product, but alas the other annoyances are hard to overcome....
  11. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    mainconcept PVR is crap.
    Mainconcept 1.4.2 work far better on this (who knows why...)
    For BT cards, when you capture realtime mpeg 2 with mainconcept 1.4.2, just use the btwincap drivers and set input 768 x 576. If you use the mainconcept engine for the realtime mpeg 2 convertion and 1/2 D1 with an average of 2600, the picture is more than excellent!
    Of course, forget this with CPUs lower than 2200Mhz
    Offline encoding are always better on the fly software ones.
    We need a guide for capturing realtime with mainconcept 1.4.2 and I don't have the ******* time for it...
    Hell, I don't even have time to end my DVB article...
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    Anyone tried Win DVR? It's not bad, though I still prefer ATI MMC.
    Mar 2004
    as I understand it.... windvr does not support firewire or interlaced capture.... So no go in my system....
    Mar 2004
    oh... maybe it does support firewire... I was just reading the discription on the website... still... $80 I'm not so sure...
    At that price I might as well get a AIW 7500ve card!
  15. Video Restorer lordsmurf's Avatar
    I'm working on one this very minute. Trying to get PowerVCRII to finish first, then a MC 1.4 guide too (though I believe at $120, it'd be cheaper to just buy a good ATI or Hauppage card instead ... people that went cheap on the card are not likely to NOT go cheap on software too).
  16. Video Restorer lordsmurf's Avatar
    Forced deinterlace = trash
    Clifton, N.J. USA
    Which software is the best for capturing with a Hauppauge 250 card, which I just received via UPS last night. Is the software that comes with the card any good?
    Thanks!
    Thanks!
    Yes. Use that.
    To double-check, which software are your referring to (cards often comes with several programs)
    Clifton, N.J. USA
    @lordsmurf
    Thanks for the reply. Actually, I am not even sure which software came with my card. I received the package yesterday;however, I did not get a chance to install the card yet. Between entertaining my kids and playing the new "Thief Deadly Shadows" pc game, I used up all my free time last night.
    Hopefully tonight after work I can get to tinker with my new toy
  20. Goonch; I'm using Beyond TV3 with my PVR 250 Card. The software that came with the 250 is ok but I prefer Beyond TV3. I'm trying a trial version of SageTV Recorder and so far it's working good. From what I seen from SageTV Record I may buy it when the trial runs out.
  21. The Old One SatStorm's Avatar
    ATI and MMC is a good alternative for the NTSC users, but many PAL users report issues. Maybe those issues are their fault, or their is indeed issues, but there are so many, we can't simply ignore them.
    So, mainconcept 1.4.2 is the only solution for the PAL users who wish a good alternative for realtime mpeg 2 capture the software way. For NTSC users they might be better (cheaper) alternatives.
  22. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Goonch
    You have few optoin here
    BeyondTV, SageTV, GB-PVR or JovrPlayer
    There a few other but a bit on bit side see www.shspvr.com under Tools
  23. Video Restorer lordsmurf's Avatar
    Originally Posted by SHS
    Goonch
    These are nice if PVR is the goal, but for MPEG capture quality, I think they blow chunks. For this reason, they lost out on my MPEG capture guide project.
  24. How about the freeware GotTV PVR?
    http://www.gottvpvr.com/
    It needs an MPEG2 codec, but works with a several different video cards. I like the fact that is has a built-in EPG easily viewable on a TV screen (unlike the ATI CrapStar guide).
    jawgee
  25. Video Restorer lordsmurf's Avatar
    Anything that requires WINDOWS XP is not an option. GOTTV uses INTERVIDEO MPEG2 codec, which is the same trash used by WINDVR (deinterlaced recording )
    Don't care about timeshifting. Merely want MPEG recording software. If it had zero PVR abilities (no timers, nothing), it would be even better.
  26. Member
    Clifton, N.J. USA
    Thanks to everybody for all the input. I really do appreciate it!
    My primary function for this card is MPEG quality capturing of family VHS tapes to DVD. My secondary function is PVR. I need my own TV
    If the MPEG capturing doesn't work out, I will most likely look to a stand-alone DVD recorder which my whole family would be able to benefit from as opposed to me purchasing a device such as a Canopus ADVC 100.
    I have been lurking on these forums for almost a year reading and trying to learn as much as possible about this very confusing, and at the same time, thrilling hobby. This PVR-250 card is my first hardware purchase and I am nervous as hell about it.
    You are some of the most helpful and energetic people that I have had the pleasure of meeting on the net.
  27. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    There nothing to be nervous about Goonch
  28. Video Restorer lordsmurf's Avatar
    Originally Posted by thecoalman
    Lordsmurf,
    That's a big no-go here. Does not see the ATI or AVer cards I have here for testing. I doubt it can be hacked (ATI MMC is the same way).
  29. Video Restorer lordsmurf's Avatar
    New install of Windows XP ... shows preview screen this time ... but no image. Just sound. Captured file is blank. ATI AIW 7200 card, AVermedia card
    TRASH TRASH TRASH TRASH ...
  30. Member
    Mar 2004
    One more thing to add to the pile o'....
    I just noticed that all the caps from this program are 25 FPS and I don't see any options to set it to 29!! I'm feelin' like I paid to be on their development team. Sigh.... maybe version 4.8 will be a winner!! hahahaha
