Hello all,
I'm new to this so would someone please help me. I'm trying to make VCDs from my DV camcorder. I've got all the capturing and burning tools. The question is which video and PAL VCD formats that produce the highest quality (as best as possible) when play on standalone DVD/VCD player? I've tried SVCD from MPEG2 but the quality isn't so great. Any suggestions?
as I've guessed from a DV source best way is SVCD and from analog source is VCD, but the most important thing is bitrate, try to raise it to around 2.5mb
hmmm u can make very very good VCDs from DV source, but, for some unknown reason I have not come accross any method where u can get decent SVCD from DV source. Even raising bit rate to 3M/s I can still see blocks but only when there is fast movement.
I am repeating myself but I can get get excellant SVCD @ 1.5M/s from a DVD rip....but DV seems to need more bit rate. I have given up for now until someone somes up with some kind of DV filter that does not take detail away but maybe "cleans it up" so that it only needs a more reasonable bit rate.
Right now I am just waiting for DVD-R to become cheaper, then I can just throw more bit rate at it.
BTW tryed TMPGE, CCE others.
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
