Hi everyone!!
I have used TMPGenc to convert programmes (alright then, episodes of friends) so that I could fit 12 episodes onto a dvd (as I thought I would be able to fit more vcd encoded files onto a dvd). I have nero 6 and usually use nero express, but when I try to add files to the dvd I get invalid file format error.
Is there something I am doing incorrectly, or can this just not be done?/
All help appreciated.
for VCD style files on DVD you need to be using 352x240, less than 1.8Mbps video and 48k audio. try using tmpgenc dvdauthor to create your DVD files.
Yes, you're using Nero for other things than burning, and yes again, it can be done. Use a real DVD authoring app to author. To author VCD material as DVD, use TMPGEnc DVD Author as flaninacupboard suggests.Is there something I am doing incorrectly, or can this just not be done?/
/Mats
Whats a good cd/dvd burnig software to be used mainly if not only fot data?
By Denvers Dawgs in forum ComputerReplies: 11Last Post: 12th Jun 2008, 03:42 -
Burnig issues for making MTV styled CD/DVD. Looking for help.
By Andretti in forum Newbie / General discussionsReplies: 9Last Post: 27th May 2008, 23:09 -
DVD video burnig on asus rom
By tapal in forum Authoring (DVD)Replies: 0Last Post: 26th May 2008, 00:16 -
Nero burnig problem.
By BradBo1140 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Oct 2007, 06:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
