My daughter turned off computer when my 13GB (-> 4.7GB) movie was 80% decoded or after 12 hours of work. I used TMPGEnc. Is there a way to start off where my computer was turned off rather than from the beginning.
Results 1 to 10 of 10
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
No. You mean "encoded", right?Originally Posted by mbekkaliWant my help? Ask here! (not via PM!)
encoded I assume
Find out time code where it stopped
Fire up tmpgenc again load your project and look in settings -> advanced dbl click Source range and set new start point where you want it. -
Well, I have not saved the project explicitly as such cannot load it, there are 2 files on my HD now, one is full 13GB avi file and another is 3.5GB mpeg file I guess I would have to run TMPGenc from the beginning.
May be I can encode the rest of the AVI file into a new file and then somehow merge them?
If it were me, I'd start over. MPEG-2 doesn't join very well.
If you would have re-started the encode instead of asking the question, you'd be done by now (14 hrs between 1st post and 2nd).
Just like some of the people trying to put their downloaded copy of a movie on DVD (or even backing up their own DVD), spending days on it, getting 10 coasters, when the DVD costs $10-$15. Not aimed at you, mbekkali. -
Well, my kids disrupt encoding all the time as such I encode during the night. Since it takes about 12 hours to encode the movie and my kids have 11 hours to sleep then there is a high chance they might either turn off the application (my 3 year old) or power down the computer (my 1 year old daughter).
Lock the door, or give up on it.
I have a server that's locked in a closet so no one interferes with it.
How to continue with 2nd pass if you have .stats and .mbtree files?
By ad.vid in forum Blu-ray RippingReplies: 1Last Post: 21st Dec 2010, 14:28 -
Is it possible to force Ripbot to continue after crash/reboot?
By yorkman in forum Authoring (Blu-ray)Replies: 4Last Post: 12th May 2010, 19:37 -
Any reason to continue using my parallel printer cable?
By zzyzzx in forum ComputerReplies: 25Last Post: 19th Jun 2008, 07:51 -
How to choose continue video lighting (non-heat style) ?
By AAC in forum Newbie / General discussionsReplies: 0Last Post: 13th Mar 2008, 17:03 -
MISSING PROGRESS.APP hence the encoding doesnt continue
By drevinko in forum DVD RippingReplies: 1Last Post: 26th Feb 2008, 22:17
