The thriller is this:
I have a secondary HD with a secondary OS used only for editing, I do that for more stability and no conflicts, the software I used for capture is Adobe premiere 6.5 and now the PRO version.
I had try 3 camcorder in my system: 1 Sony TRV19(mine) and 2 Sony TRV30 from my friends, the incredible thing is that with my trv19 and one of the trv30 I had dropped frame(a lot), audio clipping during playback during the capture, and no export, absolutely no export , with this two Camcorders the export is not possible because (they have DV-in of course) the image doesn't appear in the LCD and this one when I try to export start to shaking(not fisically but the screen). With the other trv30 all works, it's incredible, I can't understand... with this camcorder no drop frames and good export and I captured about 10 gb of video with this cam, so the trv19 had changed the motherboard in warranty after one year, I say to the sony technician that the Cam after the sustitution doesn't export but told me that with the new motherboard everything work good, the trv30 that doesn't work with my system is new(about 2 month) and the Trv30 that work my system is new too, last thing is that when I bought my Cam(trv19) I tried immediately to capture-edit-export and all worked very good and I used two software Adobe and Avid Xpress Dv 3.5(now avid refuse to capture for the drop frame) so it's incredible that after 5-6 months nothing work. What do you think about it?
Sorry for my english, I'm from Italy.
thanks a lot
Gutzs
My post is about Dv capture , wha's the problem administrator?
The camcorder sony trv are miniDV, it's OK for you? -
DV capture is not like analog capture, so it belongs in the DV forum - not the analog capture forum, okay?
Ah.... Sorry, I did a big mistake, thanks for your correction, was very usefull, sorry and thanks again...it's my first time in this forum and you know that the italian people are hothead.
problem with fairuse Wizard
By minkz in forum Video ConversionReplies: 4Last Post: 4th Oct 2011, 15:06 -
Problem with Seagate Disk Wizard
By bevills1 in forum ComputerReplies: 13Last Post: 11th Apr 2009, 06:51 -
FairUse Wizard 2.9 muxing problem
By herbapou in forum DVD RippingReplies: 2Last Post: 17th Mar 2009, 12:21 -
Problem with Fair Use Wizard 2.8 Pro
By rreadysetno in forum DVD RippingReplies: 0Last Post: 3rd Oct 2008, 13:21 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 15:30
