Hi All,
I'm trying to import NTSC video into Adobe Premier Pro using the Canopus ADVC-100. I'm using the S-VHS output of my JVC-S7860 video player (which can play NTSC and PAL) attached to the analogue inputs of the ADVC-100. When i import PAL video everything is absolutely fine, the picture quality is suberb and the audio is of suberb clarity. However, when I play NTSC tapes, the picture quality is fine, the sound is great, but, I lose ALL colour. Essentially, every NTSC tape i've tried to import has been in black and white.
I'm not doing anything as obvious as forgetting to set the DIP switches on the ADVC-100 and of course, the original tapes are in colour.However, it must be noted that when i do change the DIP switch to PAL, the picture comes across all garbled (as would be expected) but there is colour clearly visible.
I have tried changing the device settings in Adobe Premier from Pal to NTSC, but I've had no luck.
It's also worth saying that I've tried using Arcsoft Showbiz and the same problem occurs.
P.S. - the NTSC tapes in question are not Macrovison Protected.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
