What is DMA? My Samsung 16x dvdrom sd-612 model needs this turned off for me to be able to rip dvds. If it is on, then I get the blue screen of death. I read on the forum that it's better to have this option on, but I cannot have it on or smartripper will not work. Any solutions? Furthermore, do i need sync data transfer enabled or disabled?
Thanx for your time
KidMD
DMA stands for direct memory access. What it does is allow you to basically bypass the cpu when reading from a disk. The info goes directly into memory speeding up the read time dramatically. Having DMA enabled makes ripping a dvd much faster and it really should never cause any problems. You might have a driver conflict somewhere. I recommend you try updating all your drivers including the dvd-rom and your ide controllers. sorry off the top of my head I dont know exactly what sync data transfer does but I believe it should be checked because it will speed up ripping.
MPEG2 conversion related questions
By nb23 in forum Newbie / General discussionsReplies: 20Last Post: 23rd Sep 2009, 00:22 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
Gspot Specs Related Questions.
By scott274 in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2008, 22:09
