In virtualdub>options,it says display decompressed output shift + F10.
How do I use that? When I select it,I don't see any output,the frame stays at the same,how do I use it?
Btw,which quantizer matrix is the best for MPEG2 encoding? I am encoding mostly cartoons,in MPEG2 format,but it ain't from a DVD. Which quantizer matrix should I use to get the lowest quantizer possible? (lower quantizer means better quailty,usually)![]()
VirtualDub doesn't play audio in preview
By Sebastian2011 in forum EditingReplies: 20Last Post: 19th Mar 2012, 04:33 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Virtualdub - No Preview during Capture
By FatBoy123 in forum Capturing and VCRReplies: 5Last Post: 6th Jun 2010, 04:14 -
Preview help
By jmurr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Mar 2008, 14:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
