Currently I am using Smart Ripper, then DVD2AVI, then TMPGEnc. Is this the best way, or is there another way, that I can get better quality? The software doesn't have to be free. Gracias.
I had best luck with the same combo. I made a few VCDs from DVDs. My copy of Spaceballs came out perfect. I could not even see the different from the DVD. I cut out the credits and used the highest bitrate I could and 720x480 res.onger movies haven't came out quite as well for me because I have to either use a lower bitrate or 3+ discs.
For standard VCDs:
There are two main ways... DVD2AVI --> TMPGEnc or FlaskMPEG + plugin (e.g., Panasonic).
Quality is similar. It depends on whether your eyes think TMPGEnc or Panasonic is better.
The FlaskMPEG method is slower but tends to be foolproof. I reckon that it is a better method for subtitles.
The DVD2AVI method is faster and works better with TMPGEnc. It is not foolproof (e.g., read the forums --> some people have A/V sync issues, audio quality issues, soundtrack selection problems, frameserving problems, etc).
Regards.
Michael Tam
w: Morsels of Evidence -
Then what software do you use? I use Nero 5.5.5.1, and it gives me "not enough memory" error when I select option for Video CD. Can i use the option for data disk instead?
Win ME, 128 Mg RAM/5 GB free disk space/800Mhz P3/75-80% resource free.
Nero burns audio and data fine...just not video cd
Thanks -
I personally don't use Nero. IMHO, from v5.0 --> 5.5 it turned into bloatware with a whole host of weird and varied problems.
I author my VCDs with VCDImager. I then burn the CUE/BIN images with CDRWin.
For people interested in authoring VCDs with VCDImager, an article series is in development here: http://www.geocities.com/medinotes/vcd
On how to burn CUE/BIN images: http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
You can also use VCDImager with a number GUIs including TSCV and VCDEasy.
Regards.
Michael Tam
this my method
martripper
:dvd2avi only video
:vobsub ripp the ac3 or wav
:azid if i ripped the the ac3 file
:tooLame
:Vfapi codec reader to make a fake avi only when i want subs
:Vdub to make the subs and framsevere to
:TMPGEnc
:Nero 5.5.4.0 to burn(never had a problem with it and i have 128 mgs Sdram i think u should go back to a previous version like 5.5.4.0 or 5.5.3.5)
it might have alot of steps but it gives outstanding results
Best utility and procedure to modify DVD
By cryptowiz in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2011, 08:59 -
correct procedure to edit camcorder dvd using NLEs
By codemaster in forum EditingReplies: 1Last Post: 12th Dec 2010, 23:57 -
HD video to DVD procedure
By feh in forum Authoring (DVD)Replies: 5Last Post: 9th Aug 2009, 23:48 -
DVD Shrink with DVDStyler Procedure?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 11:52 -
Special DVD creation procedure
By Nick/Athens in forum Newbie / General discussionsReplies: 9Last Post: 28th Nov 2007, 23:13
