I am new to burning VCD's. I am using TMPGEnc to convert AVI to MPEG-1. I then use Nero Burning Rom to burn the MPEG-1 to a CD-R. Everything goes well but when I play the disk in my stand alone DVD player I do not have sound and the picture quality seems to be that of an SVCD. Yes I am selecting VCD and not SVCD. By the way the MPEG-1 also does not have any sound on my Nero Player. The AVI is DivX codec compressed. Any advice will be appreciated.
I'm not much into vcd/svcd, so you may want to check the 'how to' guides. They have ALOT of helpful information.
I believe you will have to demux the audio and input it after you encode the video using TMPGEnc plus (authoring tool).
If anyone else can help? I just took a stab at it.
Check the avi with Gspot and make sure you have the audio codec installed.
Extract the audio from the avi to wav using virtualdub (audio>full processing mode, save wav) then use the wav as the audio input when you convert with TMPGEnc."Art is making something out of nothing and selling it." - Frank Zappa
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
