Hi,
Is there tools that can record avi movie incrementally to the
minidv camcorder without having human interaction to forward
the tape to the place to record?
What I want to do is to archive my recording to tapes, but each tape
will have it own topic, so I need to incrementally archive my new
avi to the archive tape.
Currently, I use Studio 9, it does not seem to have that feature.
Thanks for the response.
My previous email might not be clear enough. What I am want to have
is a tools that can find the end of previous recording on the tape and write the new avi to it.
For example:
First, I write "movie1.avi" to a new tape
Second, I do the rewind on the tape for viewing or other purpose,
Now, I have a new movie2.avi that I want to write to the tape,
I would like the tools to find the end of movie1.avi and append movie2.avi to the tape, So, I do not have to find the end of movie1.avi before starting to record movie2.avi.
If I have to manually find the end of movie1.avi on the tape, I might overwrite part of movie1.avi or there will be gap between movie1.avi and movie2.avi.
If there is no tools that do it, Can somebody suggest how you handle the appending of new avi file to existing tape?
Thanks -
You can try this one - http://www.scenalyzer.com/
It's a nice software to transfer video from/to miniDV camcorders. -
i dont believe scenealyzer can do what he wants though. i dont believe ive ever seen a software that can do what you want. your best bet is just to manually fast forward to the end of video1, and then record your new video. as for overwriting or leaving a gap, just use the camera's slow motion feature to get the tape exactly where you want it. you could even add a frame or two to the end of each video you make that has something on it so you know exactly where the end is, like put a frame or two with a small X in the corner, so when you see the x, just stop the tape, and it will be at the spot you need it
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
Unable to record audio with game cam
By Crimson in forum Video Streaming DownloadingReplies: 2Last Post: 25th Apr 2011, 10:04 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42 -
Program needed to record web cam at high quality
By drug3188 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Oct 2009, 16:45 -
What are Good software i can use to record videos with my web cam or camera
By jace89 in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2008, 16:08
