If you hold down the shift key when you hit delete, Windows will not move the files to the recycle bin, but delete them instead.
Sometimes I think alot of the posts are jokes
Its as if people don't care to explore the software they're using to test its capability. How do I delete a file? My answer: are you sure you need a computer? What do you want to do with it?
Hi,
I'm trying to make a VCD, but my pencil point keeps breaking on the plastic bottom of the CD-R. Should I choose a different media?
I'm having trouble making the "pits". I've tried both pencil leads (see above) and pins, both won't encode it properly. Also I can't get the images I drew to stick to the TV screen. And they don't move!
HELP!!
<font size=-1>[ This Message was edited by: homerpez on 2001-07-24 08:32:38 ]</font>
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 06:41 -
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 13:52 -
Deleting subtitles from videos
By angeloslev in forum Video ConversionReplies: 1Last Post: 23rd Feb 2011, 22:33 -
Deleting Audio Tracks
By cmars in forum AudioReplies: 2Last Post: 28th Apr 2010, 10:00 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 28th Dec 2009, 00:10
