Hi All,
I have a Sony TRV22e, have just realized that the firewire port in the camcorder does not work properly. I have come to this conclusion after geting advise from this forum, and doing a lot of tests!!! (checked it with differnt firewire cards, cables, different PC, different operating system, etc...) Now I have 2 questions.
1. Is there any difference in the quality of the video, if I use USB cable instead of the firewire? (and is there a big difference in the speed of downloading) If not, I can use the USB cable. I'm a bit reluctant to give my new camcorder for repairing, unless it makes a big difference.
2. Write now, when I use my USB cable, the pictures I get are blurred (looks like dots of water had been on the camera lence). But, when I used my camcorder in another computer (through USB), the pictures were ok. Do you know how can I improve the quality?
Thanks in advance....
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
2. Write now, when I use my USB cable, the pictures I get are blurred (looks like dots of water had been on the camera lence). But, when I used my camcorder in another computer (through USB), the pictures were ok. Do you know how can I improve the quality? -
Hi,
Thanks for the reply.
no , you cannot use usb to transfer dv video from your camcorder. usb is meant for transferring stills, not video.
Thanks.... -
while you may be able to transfer video through usb, its not nearly as fast as firewire, and therefore the video will not be good quality as you said. firewire is a straight digital to digital transfer of the dv avi file. usb will not make a true dv avi file.
Help with captureing 360 footage!
By sXemosher in forum CapturingReplies: 2Last Post: 30th May 2010, 20:08 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
Captureing Video off tv
By MoDifiy in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2008, 00:23 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum CapturingReplies: 5Last Post: 16th Jun 2007, 03:03
