hi, i hope someone can help me. I cannot any longer record anything on CD as after a while, Nero stops saying "Could not perform end of track" even if it was jsut started.
I re-intalled the software but still the same problem.
Do you thinks it is the CD writer that is now broken (even if i can use it for playing cds!)?
Thanks!!!
hi alessio71,
It could be that you probably got yourself a bad batch of cd-r's. Did you try with a different brand of cd-r? Also, did you make any changes to the write speed in Nero?
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
