  1. i just got the Ritek 9.4GB DVD-R 4x Double Sided Blank Media
    my question is while burning a DVD will nero stop and tell me to turn the blink DVD over after it write the firt 4.7GB to continue writting the other 4.7GB ?
    I have the hival internal 8x rewritterable daul format dvd-r and +r drive
    USA
    I doubt it will tell you to turn it over. You need to burn double sided discs just the same way as you would burn two seperate DVD discs. Must be hard to tell side one from side two after the burn.
    Mar 2004
    Region 1, biotch!
    dang, last time i checked thse things were a fortune, glad some1 can afford em
    Yellow-Haired Warrior...Go
