I have noticed that on my PC when i turn it off then back on; it light up for a split second then go back off. The PC does not turn on again until it unplug the power supply power cord until the keyboard light go off. Then i can plug the power cord back in and turn the PC back on as normal.
Does this indicate a faulty power supply?
N.B. I also have to reset my CMOS settings
Sounds like the power supply. Easiest to replace the PS with a 300W version at least. If that doesn't cure it, then you have bigger problems. If you lose your BIOS settings, then that is usually a dead BIOS battery. You would lose your clock settings also. If so replace the battery.
Not by itself. Check your cmos settings under power off andDoes this indicate a faulty power supply?
change them to soft/off power off via power button. -
I've been through this twice now with the exact same symptoms. In both cases, it was the power supply.
I stopped burning up my Power Supply's after i bought a UPS.
By the way, you don't have to wait for the light to go off. After pulling the plug, press and hold the power switch for a few seconds, it will drain the power out quickly.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 04:48 -
Problems in different equipment with .mpeg1 in Power Point
By carlosarano in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 10:25 -
Power problems with Canadian Xbox 360 is Australia
By ryangarfield in forum Off topicReplies: 3Last Post: 15th Feb 2009, 04:04
