  1. Hello,
    Is there any way to find a list of Codecs on my computer? Is there a place I can look to find this?
    What if I want to copy one of those Codecs to another computer? Could I simply copy it from Computer 1 and paste it in Computer 2 somehow?
    Help.
    Foo
  2. It would be most helpful if you could tell us what operating system you're running.
  3. Windows XP Home Edition
  4. Go to Control Panel -> Sounds and Audio Devices -> Hardware Tab. Select "Video Codecs" and click the Properties button. Yet another dialog box will open, click the Properties tab here. This will list the codecs you have installed, and allows you to remove them or add more. I have no idea why the codecs are listed here. Unfortunately I have no idea how to easily copy the codecs from one system to another. You would probably be better off just installing the codecs on the 2nd system.
  5. Mod Neophyte redwudz's Avatar
    USA
    AVIcodec will give you an easier to understand listing, besides giving you information on attributes of video files. Most any codec you need can be found in the 'Tools' section to the left. Use AVIcodec to find the ones you need from the video files you want to view. Too many of the wrong codecs can mess up your system. I would recommend only installing the ones you need.
    Jan 2004
    PAL Region
    GSpot -> View -> Installed Codecs ->Audio/Video.
    Mar 2004
    Anyone care to list their "must have" and "must delete" codec guide??
    I'm still kinda hazy in codec land....
    Jan 2004
    PAL Region
    The best advice I can give is to only install what you need. Once you come across a file that won't play, use Gspot and then see what will decode it. Don't install any more than you need due to some that conflict with others by wanting to override them during playback.
    When you do need a particular codec, you'll find it pretty easy just by a little bit of research. There are a number of 'big name' codecs that you hear about more than others and these are the ones that have more mature development than other 'hacks'.
