is this possiable the reason i ask is because i couldn't find a guide in the guide section as you can tell i'm anewbie (sorry) if it is possiable can someone kindly point me in the right direction
i have a movie that i encoded from avi to mpg and now i would like to burn it to a dvd i just don't know how to do it
i have dvd xcopy alcohol 120 and nero and dvdshrink so again please help
thanks all
you need to use some sort of authoring program, such as tmpgenc dvd author, dvd-lab or ifoedit to create vob files, then you can burn it using your favorite burning software.
tyvm dafreak
if it not to much to ask could you recommend one and maybe point me to a guide
thanks again -
tmpgenc dvd author is pretty easy to use and works pretty well. I would recommend that for starters.
here's a guide that may be helpful.
http://www.dvd-guides.com/guides.php?category=dvdauthor&name=tmpegencdvdauthor
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 17:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
