In latest sound and vision I saw this quote in DVR-810H review:
"First, as in every hard-disk recorder, the DVR-810H's hard drive is always on, and in q quiet room you can hear it whirring away".
Is this a general problem with HDD recorders? Although probably non-HDD recorders may also have a fan that makes noise. Anyone bad experiences with this?
Interesting question.. I would have thought that the HD would spin down after awhile as they do on PCs when the power option is set..
If theHDD recorder has a "time slip" fuction then the drive will be continually running to record/relay live the picture.
This is how Tivo works, I'm assuming that other HDD recorders work same/similar.Bad advice is pricey...good advice is priceless
I can't warrant what camp this falls into, but, for what it's worth, it's what I believe! -
I've got the Panny E85 and both the HDD and Fan are wisper quite. The HDD does indeed sleep after a peroid of inactivity but you cannot audably tell that it has as it's so quite even when powered up. The fan is on all the time the unit is on but again extremly quite but in a dead silient room you can tell the unit is on. I would say this is no worse then a DVD player spinning a DVD Rom.
I think the only way you are going to get complete 'silence' is with some sort of solid state storage and therefore no mechanical or moving parts - which for the capacities we need for Video is still some way off ...
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Fan noise
By alintatoc in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2009, 11:48 -
Panasonic E95H Harddisk unformat
By Flyrider in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st Sep 2008, 18:46 -
I'm looking for a multimedia harddisk
By andyr74 in forum Media Center PC / MediaCentersReplies: 9Last Post: 30th Apr 2008, 13:16 -
Panasonic DVD recorders AV-in NR (noise reduction)
By JoseD in forum RestorationReplies: 2Last Post: 5th Jan 2008, 00:04
