  1. Recently I purchased the Superbit Jurassic Park trilogy on eBay thinking it was the official one. I ended up with bootlegs of the original Superbits. The quality is the same and all but as with all bootlegs the chapter selection stops are off by a few seconds. I've ripped the first movie DVD to my HD and all I want to do is correct the chapter stops and fix the Chapter Selection menu to correspond to the fixed chapter stops. I don't wanna mess with anything else and I want to be able to author and burn the DVD on a DVD9 [coming out soon] and have it play just like it did before... except with fixed chapter stops. How can this be done and with what program?
  2. Only thing that I can think of is using the Big3 method (doitfast4u, reauthorist, and docce4u), and when it comes to the part you author with scenarist, manually change the chapter points. But this is all in theory, and well let's just say I'm not a very good theorist. Of course remember to make sure that your settings are high enough where you don't re-encode and such.
    Blah, blah, blah
