I am very fustrated. My Hiteker 620 will not play CD-R or CD-RW. It is the same unit as the VDDV DVD-620 with just name change (and same manual), but the later will play the CD-R and CD-RW. Hiteker also makes Apex and they all seem to play these formats. Is there any help or am I just stuck with lower grade equipment?
Is this a firmware issue that could possibly be corrected, or is just a possible hardward laser difference.
Thanks for any help.
Don
Results 1 to 1 of 1
does this work
By sve in forum TestReplies: 7Last Post: 21st Apr 2012, 23:15 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Does not work.. What can i do?
By schr2004 in forum ffmpegX general discussionReplies: 0Last Post: 24th Jul 2010, 16:21 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35
