Hi,
I've encountered a problem with PVAStrumento. I can't demux the transport stream from the sat-tv channel Showtime EX. The recorded stream plays perfectly well on the sat-tv receiver (Dreambox 7000) and it is also played without any problems by PC video-players such as BSPlayer or Windows Media Player.
The thing is particularly strange because several months ago I was able to demux programs from the same channel without problems.
I would be very thankful for any advice.
Here is the PVAStrumento log:
*** PVAStrumento 2.1.0.8 build 97
*** running at 05-18-2004 21:04
Pre-Scanning input. Takes some time.
Stream tagged as SCRAMBLED [ignored...]
Transport stream contains more than one program.
[PAT refers to 12 programs.]
Stream info for
F:\Documents and Settings\User\My Documents\My Videos\Films\Farscape3.ts
Found 1 video stream.
Found 3 MPEG audio streams.
VIDEO #1
Resolution 544 x 576
Aspect ratio is 4:3
Frame rate 25.00 fps
Nominal bitrate 15000000 bps
First PTS: 12:57:53.916
MPEG AUDIO #1
MPEG1, Layer 2
single channel, sampled at 48.0 kHz.
Bitrate 64 kbps
Each frame contains 24.0 ms audio (192 bytes)
First PTS: 12:57:53.413
MPEG AUDIO #2
ALERT> No audio frame found. ("WHAT ??")
MPEG AUDIO #3
<<DEMUXING>>
Input: F:\Documents and Settings\User\My Documents\My Videos\Films\Farscape3.ts
Options
.. fixing startup delay.
.. fixing stream synch.
.. keeping track of audio offset accumulation.
.. strict checking of audio framing.
.. dropping GOPs longer than 980 KB
.. splitting on change of video format.
.. splitting on change of audio format.
.. splitting on number of audio tracks.
.. creating new GOP timecodes.
Closing starting GOP.
Audio stream 2 has no data, purging.
Audio stream 3 has no data, purging.
Aiming for sync at 12:57:53.996
Cutting audio.
Audio stream 1 now starts at 12:57:53.989
Video stream 1 now starts at 12:57:53.996
New MPEG video : F:\Documents and Settings\User\My Documents\My Videos\DVD authoring\Farscape3.mpv
New MPEG audio : F:\Documents and Settings\User\My Documents\My Videos\DVD authoring\Farscape3.mpa
Last fileset:
413000 total bytes written
Video 1: 22 frames, 00:00:00.880
Audio 1: 37 frames, 00:00:00.888
Approx. sync at EOF:
MPEG Audio #1 : sync
Hi,
sorry, I cannot help you with your problem. But I see that you are way ahead of me as a dreambox-newbee in the knowledge of how to use the dreambox.
On www.dvdrhelp.com there are no guides available for the dreambox 7000, so just let me know how you learned all about this awesome machine.
I have the following problem:
My dreambox with a 120-Gig-HD ist connected to py PC via ethernet, and the network-connection ist fine (dreambox is found in Internet-Explorer when entering the IP, the ping-command returns no mistakes). I am just not able to download the recorded films from the Dreambox-HD to my PC. Films are shown on the webbased infopage in IE but cannot be double-clicked.
So please just let me know to which forum/guide you went for questions when you were a newbee.
Thanx a lot for your help,
Stefan@eckelmann.net
Combine two transport streams.
By Deadeditor in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 09:12 -
Seeking in Transport Streams(.TS)
By deepp in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 17:00 -
Joining transport streams ?
By NotSoEasy in forum DVB / IPTVReplies: 7Last Post: 3rd Jul 2009, 19:32 -
Converting Transport Streams to AVI
By RedPenguin in forum Video ConversionReplies: 3Last Post: 14th Apr 2009, 23:56 -
European transport streams
By branch in forum DVB / IPTVReplies: 26Last Post: 27th Mar 2008, 04:50
