is it a bad idea to use other applications while tmpgenc such as internet explorer?? obviously, it will take tmpgenc longer to run, but will it lower the quality of the output?
Depending on your CPU, I find that if the other applications aren't too intense then there's no problems. Surfing isn't a problem. You can set the CPU task priority for TMPGEnc under the environmental options.
"Art is making something out of nothing and selling it." - Frank Zappa -
I see no reason to not use the pc as normal while encoding. With CCE i start with /LOW priority, doesnt even notice it is running. With tmpegenc you dont have to do even that much, it defaults to Low priority when inactive. Grimey is talking about unstable systems, some of those can fail even if left alone while encoding.
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
TMPGEnc author4 running codec twice
By BRck in forum Software PlayingReplies: 2Last Post: 4th Feb 2009, 06:47 -
Any other apps.... mkv->divx WITH 5.1?
By biggyk in forum ffmpegX general discussionReplies: 5Last Post: 26th Jan 2009, 12:03 -
Portable Apps
By chrissilke74 in forum ComputerReplies: 5Last Post: 29th Jun 2008, 10:04 -
Tested apps to speed up transition??
By willmoodom in forum Video ConversionReplies: 3Last Post: 9th Nov 2007, 20:30
