Hello,
If I install this Codec on my system - Canopus DV Codec - will I be able to capture AVI files in the Canopus DV AVI specs? I'm using PVR Plus (Xpert TV - PVR 878) to capture clips from TV that I want to eventually put on my system with DV Storm 2 and Premiere Pro to edit.
Foochuck
You will be able to open DV files. You should be able to with MS DV codec anyway.
Hello.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Hi8 to DV-AVI: Analog to Digital Passthrough or Canopus ADVC55?
By Ear Whiskers in forum Capturing and VCRReplies: 8Last Post: 8th Feb 2008, 22:23 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
