  1. Hi...I got some mp3 mixes, I just wonder is there a way I can place like chapter or points on these so I can go quickly to without holding my forward or backward button??? Or pretty much I have to split the mixes into different tracks??
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    depends on what you use to play them back. a lot of media players allow you to "bookmark" a recording.
    you can of course decode to .wav and split it into tracks - useful to then stick on CD.
  3. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    if your mp3 is only one continous song, then you need to split the mixes into different tracks.
    if your talking about several mp3s, then you can burn them to CD-R using Nero 6...choose Music then MP3 Disc on Nero. Nero will create the tracks for you.
    then you can go to any songs or tracks by pressing the number in your remote in case ur playing your mp3 using stand alone mp3 player...
    hacking the Net using typewriter :D
