Hi
I have made a dvd from a avi file and everything plays ok but it is in cinema scope, as I no-longer have the avi file is it possible to change the dvd ie re-author to show full screen then burn the results onto a new dvd.
alk
ps. tried tv settings but I only get cinema scope or smaller.
It's not worth the effort. You will have to re-encode and chop the sides of the frame off to make it full screen. Get a bigger TV if widescreen bothers you so much. It's not going away any time soon.
video formatting/ picture size
By rocks911 in forum Video ConversionReplies: 4Last Post: 7th Dec 2011, 18:47 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Vista Media Center Live TV Picture Size
By jbartosh in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Aug 2008, 15:59 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 08:04
