Hello,
I have 2 files that i wont to join together to beable to encode to MPEG2 then burn to DVD.
I am using VirtualDub to try and join the files.
I open the first file in VirtualDub and get this error,
I click OK on that error then select append AVI and open the second part and get this error,
Heres the file information for the first file,
Heres the information for the second file,
Why wont they join together ?
Cheers![]()
gsvgaming.net sponsored by 4u-servers
You have two choices:
-Convert the audio to wav and then join.
-Don't join them at all. Convert seperately and then author them so that one plays after the other.
I'd go with the second, less problems."Art is making something out of nothing and selling it." - Frank Zappa -
hey ZippyP., I have the same problem when i try to join two avi files....Adn you said that it is probably better to convert first and then to put on Dvd toghether....Witch is the best way to do that...
I have avi's like :movie_part1.avi, movie_part2.avi... in PAL format and i want to put them on the same dvd in NTSC format. I'm using the guide "AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD" (using DVD2SVCD ) for conversion to dvd format and then "User guides - PAL / NTSC DVD Conversion (patch method)"(using IFOEdit)
Can you suggest me another ideea OR how can i use this ideea if i want to put more avi's on the same dvd....
10x a lot!!!! -
voicu_n: You need to join your files in order to use DVD2SVCD. Open the first part in Virtualdub, if you get a VBR warning then you need to decompress the audio to wav.
If you don't get a warning then under file select append avi segment and select part 2, set audio and video to direct stream copy, then save avi and give it a new name.
If you do get a VBR warning, then under audio set full processing mode, also under audio>conversion and select 48000Hz, under video set direct stream copy, then save avi and give it a different name. After doing that for both parts you can join as above.
Good luck."Art is making something out of nothing and selling it." - Frank Zappa
Help Joining Two .srt Files As One
By bigb_y2g in forum EditingReplies: 18Last Post: 6th Nov 2015, 09:07 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 20:33 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 22:00
