im using tmpgenc wizard to make dvd's with avi's
with 25fps, and 23fps files i have no problem it is straight forward, but files that are 29fps i am unsure which options im supposed to select, in the wizard i open the video file, ntsc dvd (for 29fps) film movie, then set screen size etc, then set audio and video bitrate, but for 29fps files only it seems to want to inverse telecline to 24fps? should i let it do this? or am i best off unticking the inverse box in settings?
shall i do this with all 29fps avi's? and use film movie for all others?
anyone please? just waiting for confirmation b4 i hit the start encode button, as i dont want to waste another 2 hours
If the source is 29.970fps then you can SOMETIMES do an inverse telecine but more often than not it will "screw up" as that is a very "touchy" process.
Better off just leaving it at 29.970fps and therefore NOT doing an inverse telecine.
is it possible to ivtc a 29fps ntsc source to 25fps xvid with gnot?
By iamtehsux in forum Newbie / General discussionsReplies: 65Last Post: 28th Dec 2010, 09:22 -
Changing AVI from 29fps to 25fps
By Ric76 in forum Video ConversionReplies: 11Last Post: 22nd Jul 2009, 15:12
