Hello,
I want to make a DVD from 2 Divx files.
I'm using the 0.0.9i version of ffmpegX with Sizzle 0.5b2 on MacOSX 10.3.4
I've converted the first divx with DVD preset. When i import the .AC3 file, Sizzle tell me that the audio file is not 48KHz (that's wrong) and may cause audio sync problem.
I've converted the second divx with Fast DVD preset. Sizzle tell me also that the audio file is not 48KHz and audio sync problem.
Next i launch the Save Disc Image in Sizzle, and mount my image.
When i try the DVD in Apple DVD Player, i've no audio sync problem with the first movie (DVD preset) but i've audio sync problem (0.5 sec at the EOF) with the second movie (Fast DVD).
Is it a Sizzle or ffmpegx problem?
Thanks,
Toche
Ti 867 MHz - 768 Mo - Airport - 10.3.4
ffmpegX 0.0.9m [REG] -
for some reason, ffmpegX and later versions of Sizzle aren't working too well together, if you just want to build a basic disc with no menus, then find an older copy of Sizzle 0.1, which I use and it works perfectly. Also, if you're building a disc from 2 movies, use the exact same encoding on them. The FastDVD preset works very nice for me, and I've used it on damn near every file I've got with pretty good success
One question though, your source movies, are they both NTSC or PAL or are they different? You can get a LOT of sync issues there!!! -
I have a menu with image to launch the desire movie.Originally Posted by Dunnyman
I've used 2 different bitrate for the movies (both PAL) and works perfectly with DVD preset encoding (not FastDVD) in Apple player. I will burn the .dmg tomorrow and i'll try on a home DVD player.Originally Posted by Dunnyman
Thanks,
TocheTi 867 MHz - 768 Mo - Airport - 10.3.4
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
A ffmpegX's problem about setting the audio bitrate
By lzero1319 in forum ffmpegX general discussionReplies: 1Last Post: 7th Apr 2012, 09:44 -
Funky Audio & Video Sync Problem [FRAPS]
By Sniff211 in forum Video Streaming DownloadingReplies: 12Last Post: 7th Jul 2010, 10:05 -
ffmpegx problem: no audio from QT mov to avi
By mekon in forum ffmpegX general discussionReplies: 5Last Post: 1st Feb 2008, 17:14 -
Mac OS X, ffmpegX, mencoder & Mkv with DTS audio
By ingemar in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2007, 21:31
