Hello,
I installed TMPGEnc 2.5 onto another PC so i can encode movies overnight
But i keep getting strange output files![]()
I use a 700Mb divx file and i want to convert it to MPEG2 to burn to DVD.
The output file is only 720Mb
I am sure it should be a few Gb's ?
I am only encoding the video, not the audio.
Anyone seen this before ?
Cheers
Results 1 to 10 of 10
gsvgaming.net sponsored by 4u-servers
Typically that happens when you set bitrate too low. Use the videohelp bitrate calculator to estimate the bitrate you need.
Ok cheers
You mean use this,
https://www.videohelp.com/calc.htm
Looks straight forward just a few question,
How do i know what audio bitrate to use ?
Also do i copy the "Calculated Bitrate in to TMPGEnc ?
cheersgsvgaming.net sponsored by 4u-servers -
Thats the one. Use the resulting bitrate in tmpgenc, as average if you use VBR. The audio bitrate will not take much space in the dvd so just use high enough, for many people 192 would be the minimum for AC3, 224 for MP2, but it is still individual. 256 is ok for high quality audio sources, a divx at 700MB is not likely to have so good audio anyway, 192 should be plenty.
Ok i enter the details and got this,
So in TMPGne i set it to this,
Rate Control = 2pass VBR (VBR)
Bitrate = 4267
I am unable to change the Bitrate now, it greyed out as soon as i select 2pass VBR (VBR), that sound right ?gsvgaming.net sponsored by 4u-servers -
How 'bout sleeping pills. I like the better quality with 2-pass and I encode overnight.Originally Posted by thor300"Art is making something out of nothing and selling it." - Frank Zappa
Yes AviSynth and CCE is much more powerfull and flexible than using just TMPGEnc plus of course the main benefit is SPEED.Originally Posted by thor300
Yup, CCE is still the Ferrari of encoders. I had some time to test out mainconcept a bit lately, and i cant confirm the findings of others about MC having aprox same speed as CCE. Even if i used AviSynth to frameserve to MC the difference could be more than 20% extra for MC. Sure MC is fast compared to tmpgenc, but i kinda doubt the programmers of MC are proud of that.
Having Strange Problem with after encode!
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 04:36 -
Strange Audio Problem
By Wanderlustus in forum ComputerReplies: 4Last Post: 21st Feb 2011, 14:27 -
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
Strange FLV problem
By BLboy in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2010, 01:14 -
Help with Strange Problem?
By Mitchum22 in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2010, 22:10
