Using ffmpegx version 0.0.9i
Source is AVI: mpeg4, 512x384, 29.97 fps, mp3, 32000 Hz, 95 kb/s
It's a 54 minute video.
I tried using the VCD preset with 80m mode-1, and then tried again using the 'Best' button, which established 1137 kbit/s.
clicking 'Time' showed 71 minutes possible
clicking 'Size' showed 697 MB for 71 minutes.
Both attempts resulted in virtually the same final process information:
INFO: [mpeg2enc] Progressive format frames = 1
**ERROR: [mpeg2enc] pel_aspect_ratio must be between 1 and 14 (MPEG-1)
INFO: [yuvscaler] output: frame size: 352x240 pixels (126720 bytes)
INFO: [yuvscaler] output: frame rate: 29969999/1000000 fps (~29.969999)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?;?
/Applications II/_VIDEO_TOOLS_/FFMPEGX/ffmpegX.app//Contents/Resources/mencvcdX: line 218: 1863 Broken pipe $command
++ WARN: File length according data tag: 2147479596
++ WARN: File length according RIFF tag: 2751459336
++ WARN: Inconsistency is inevitable if wav's are being piped
INFO: Opened WAV file, freq = 32000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 2147479552 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/chrome/Desktop/VCD.mpa"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] Unable to open file /Users/chrome/Desktop/VCD.mpv for reading.
Tried a few other minor variations, but no difference.
Manually altering flag to correct aspect ratio error...
By Board Room in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Aug 2008, 07:26 -
AVI Aspect Ratio
By bcd_61 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2008, 20:44 -
What best to change avi aspect ratio?
By drwho in forum Video ConversionReplies: 6Last Post: 17th Feb 2008, 05:30 -
change the Aspect ratio for an avi
By themaster1 in forum EditingReplies: 2Last Post: 27th Dec 2007, 13:27 -
Correcting VCD aspect ratio?
By gastrof in forum Video ConversionReplies: 4Last Post: 30th May 2007, 15:43
