I have done my best to search for information but have been unable to find the answer on this site. What program (s) would I use to copy only the episodes removing all else to generate the best quality and how would they be used. I am looking for a quick an easy method but am willing to put in a lot of effort if necessary If there is a guide please reply with the url. Thanks in advance.
Originally Posted by Mustang.VxD
Two words (actually, one compound): DVDShrink. In Re-Author mode, it allows you to pick and choose what content you put on a disc. It is free. What more could you want?
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Episodic DVDs: is it possible...?
By Instant Martian in forum Authoring (DVD)Replies: 28Last Post: 30th Oct 2011, 13:23 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
Best and fastest way to convert episodic DVD episodes to MPEG2?
By Y2Bogus in forum DVD RippingReplies: 2Last Post: 4th Mar 2009, 13:20 -
I want to reauthor an episodic dvd
By peterhun in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2008, 18:02 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
