The freaking things run into the THOUSANDS!!! Does anybody know how to make these things or can someone direct me to a site on how to make them? I'm looking to make a 1to4 machine.
Thanks a million...
check this out
http://www.blankdiscshop.co.uk/acatalog/Hardware_Section__.html
last three items on the page.
so then you just need some drives in there too, that's the expensive bit.
Hmm, just noticed, they say NOT FOR EXPORT. well you know they exist at least
If you can't find them anywhere else then i could sort you out
http://shop.ily.com/default.htm
They have kits that include the box and the controller. Now is a real bad time to build one. I would wait for dual layer controlers to come out before you build it, if you can wait.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Pretty sure instructions would come with the controller.
Items Needed:Originally Posted by Red96TA
Case that has floor to ceiling bays(or mod one yourself).
Power supply, for a 1to4 a 250 is fine, higher if you want a HD in it as well.
Controller card.
ROM Drive that works with the Controller Card.
Burners that work with the Controller Card.
Cables(usually come with the controller card).
Steps:
Install Power Supply.
Install ROM Drive.
Install Controller Card.
Install Burner(repeat this step til all Burners are installed).
Read the instructions for operating the Controller Card.
It really is that easy.my t.v. is wide and so am I.
acard dvd duplicator
By johnthedog in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Mar 2010, 12:08 -
By johnthedog in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2010, 14:43 -
DVD duplicator help?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 12th Sep 2009, 10:46 -
dvd Duplicator
By kingnat2 in forum DVD RippingReplies: 3Last Post: 28th Jul 2007, 08:49
