I just ripped the Matrix using DVDecrypter. Then I created a v2d file using dvd2avi. Then I used IVTC to reduce the fps. I encoded like 5 minutes of the movie until I noticed that the preview in TMPGEnc was acting up. So I played the MPEG that it created so far. Everything looks fine up to about 3 minutes int the movie. Then it will play a scene then jump back about 3 sec and play the scene again. Then it will play for like 6 sec then jump back a couple of sec and play that part again. I thought it was an error in TMPGEnc but I did a preview in DVD2AVI and it also did it in the dvd2avi preview, so I must be something wrong with the vob file on my computer because the original DVD doesn't do this. Has anyone ever heard of this and know how to fix it. Could it be a problem with the actual coping of the files from the dvd to the harddrive?
how did you ivtc? what program & exact settings did you use? what video type percentage did dvd2avi report?
If I remember correctly, the Matrix uses seamless branching. Thus, if you use DVD Decrypter to extract the vobs, there will be repeated sequences.
If you use DVD2AVI, try using SmartRipper on "Movie Mode".
Regards.
Michael Tam
w: Morsels of Evidence -
Matrix is seamless branching, if you haven't got the DVD anymore but have the ifo then you'll need to use DVDx or Flask.
help jumping from SD to HD
By blacktooth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 4th Feb 2012, 01:46 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 11:27 -
Jumping over movie
By gbabione in forum DVD RippingReplies: 3Last Post: 11th Apr 2010, 04:54 -
Jumping, Stuttering Video
By Smack2k in forum Video Streaming DownloadingReplies: 7Last Post: 6th Jul 2009, 19:36 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 07:30
