Hi, I installed SimpleDivX and followed the guide by the book. Once I hit start it loads dvd2avi and opens up a preview window (not a good idea though). After few hours the preview window closes, SimpleDivX progress bar is still half way through and nothing else is happening. All programs are running, d2a is still running but consumes no CPU. I left my computer along for more than 12 hours and have no result. Both output and temp folders are empty. What's wrong?
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
Hi. Suggest doing a search of all forums for Simpledivx. Seems like there are alot of problems. Would sure like to see a post from someone who has been successful. So far, I'm getting the feeling the application is crippled and needs some more development.
Wel, AutoGK also crashes on me and gives this error "An out-of-bounds memory access (access violation) occurred in module 'xvid'." I searched google but could not find a sensible answer. I installed the latest DivX and XVid codecs. May be the source DVD is corrupt. How do I check it and fix it.
SimpleDivX, and cropping/resizing
By snafubaby in forum DVD RippingReplies: 2Last Post: 21st Dec 2008, 17:39 -
Is SimpleDivx (Mencoder) multithreaded)...which encoders are?
By radium02 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 03:28 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 16:23 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 30th Jul 2007, 00:57 -
SimpleDivX replacement
By alan79 in forum DVD RippingReplies: 3Last Post: 18th May 2007, 12:34
