Hello, i'm trying to make a copy of a dvd that i have. However, the blank dvd's that i purchased are 4x, whereas my burner is only 2x. There's a slip of paper that came with the blank dvd's that says "firmware update required before using new 4x dvd-r discs"... it then lists all the models that this applies too (none of which are the model that i have). However, the 4x's won't work? Any ideas? or does anybody know where i can find an update for a Memorex burner (model 32023251)?
Thanks,
brds
Low and behold, I went to www.memorex.com and found this link in literally 3 seconds. Hope it helps.
http://www.memorex.com/service_support/software_display.php?id=456&dl=p
Tom -
jtommyj is correct
You have a Memorex 2.4xDVD+R/W (rebadged Ricoh5125) drive
Update to firmware 1.64 and you should be fine.
Check the current firmware version with DVDInfo PRO (also great for bitsetting)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Hitler hates AMD Bulldozer
By deadrats in forum ComputerReplies: 0Last Post: 14th Oct 2011, 17:51 -
Windows vista hates converting video??
By masadar in forum Video ConversionReplies: 4Last Post: 22nd Sep 2008, 04:18 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48
