Hi!
So basically the problem is that I can't encode with Cinema Craft Basic 2.69 anymore. (lot more detail lower in the post)
Please take a look at the output it give me:
http://members.rogers.com/bpatrice0503/test.mpg
(SVCD, so open it with an appropriate player (not Quicktime)
Flask Mpeg (078.39)
So it use to work when I tryed the Trial versions; then I bought it (59$ US) then the time I tryed, I couldn't even open Flask; it just crashed if the CCE plugin was there. Then I reinstalled the software and it worked for a few tests. Then I got to play with the settings then next thing I know All I can get in the output is what you can see on the test I showed you.
I tryed changing whatever settings, VCD, SVCD, DVD.... no differences.
I tryed to completely remove it from my computer, deleting all the files and all the registry keys I could find but I still get the same problem when i reinstall it.
I've sent an email to Cinema Craft support and the guy just told me my plugin is broken and to replace it with one of the two plugin he sent me. (2.67 and 2.69) but I still got the problem with these plugins.
(still waiting for a new email from the tech guys over there)
I've tryed to install CCE_SP Trial and it work perfectly fine when I'm compressing with it!!!!!!!!!!
I don't know what to do so please reply if you have any idea that could help me!
(P4 3.0
1 GB of Ram
Western Digital Raptor 74 GB @ 10 000 rpm
GeforceFX 5700 256 Mb)
P. B.
bpatrice0503@rogers.com
I forgot to add that the output from CinemaCraft is reverse...
Left is right and gight is left but it's not upside down.
like a mirror so you cant read anything.
And the standalone is working fine too...
Hope you pro's can help me out!!
Pat -
See http://forum.doom9.org/showthread.php?s=04ca577773fdb9a83d8668b291d424f1&threadid=53770 for the different versions of CCE..
Perhaps there's something of interest...
Good luck!!
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
GOP questions in Cinema Craft Basic v2.7
By schrakapouet in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 13:54 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
