I just installed a new DVD drive today and I am testing out my first DVD burned discs.
I am importing video from VHS tape, editing it in Premiere Pro, and then wanting to export it to DVD's.
I am using the Adobe Media Encoder and selecting MPEG2-DVD as my format. My question is which preset to choose and why?
I am using DVD MovieFactory 2 as my authoring program and it does not support separate streams so it is necessary for me to set the Multiplexing to 'DVD'.
The following are the 6 NTSC default presets for MPEG2-DVD:
NTSC DV High quality 4Mb VBR 2 Pass
NTSC DV High quality 7Mb CBR 1 Pass
NTSC DV High quality 7Mb VBR 2 Pass SurCode for Dolby Digital 5.1
NTSC DV Low quality 4Mb CBR 1 Pass
NTSC Progressive High quality 4Mb VBR 2 Pass
NTSC Progressive High quality 7Mb CBR 1 Pass
What I am seeking is a general explanation on when to use each of the presets. When should I use 'NTSC DV High quality 7Mb CBR 1 Pass' versus 'NTSC Progressive High quality 7Mb CBR 1 Pass' and why?
A much simpler question would be which of these presets is the most appropriate for creating DVD's that should be compatible with all DVD players.
Could anyone refer me to documentation that summarizes this information or could anyone please provide me input on preferred presets?
Well you have posted in the wrong place.
Maybe you'll find some answers here:
https://www.videohelp.com/author
https://www.videohelp.com/capture
https://www.videohelp.com/forum/viewforum.php?f=14
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
targa dvd/vhs recorder won't recognise dvd+rw discs.
By steve6 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 31st Jan 2011, 17:04 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
How do you preset timer on DVD player/recorder LG RC6821W
By download in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2007, 13:39
