Im now have some Matroska file *.mkv include subtitels in them !
Now i want to know how can i convert them to Mpg compliant with NTSC-VCD-FILM
I tried Tmpenc, i can convert to mpg file, but my mpg doesnt have subtitels in them like the original mkv.
How can i do now ?
Demux the subtitle stream. Open the MKV with Virtualdubmod, go to streams>stream list, select the subtitle stream and click "demux". As long as the file is named like your movie, i.e. movie.mkv and movie.srt the subs should show up when you encode again.
Is it necessary to have VSFilter.dll installed for that to work?
(I'm NTSC-land and never use subtitles)
-----------edit-----------------
Or to rephrase the question.......
Is the SUB parsed by an existing Windows filter, or separately by the Matroska Splitter?
OK, i'm convinced........it works just like you said.
1. Install VobSub and change from default "Hide Subtitles" to "Show Subtitles".
2. Use VDubMod to extract SRT file and name same as MKV
(sample.mkv / sample.srt)
3. Open in TMPGEnc and encode
I'd still like to know why it won't just play the SRT when loaded in TMPGEnc. (According to the icon in the task-bar, VobSub is loaded.) -
Yo, check this post so see if you could make it through. There are 2 of them (mine is the second (NightScream) so try them out).
https://www.videohelp.com/forum/viewtopic.php?p=1018674#1018674
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
How to include subtitles when converting avi > mpeg > dvd ?
By buzzsaw in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2011, 10:05 -
No subtitels !?
By ferrit in forum ffmpegX general discussionReplies: 2Last Post: 13th Apr 2009, 16:40 -
Subtitels off
By Russo in forum SubtitleReplies: 2Last Post: 18th May 2007, 11:05
