Hi,
I have a few Divx files that I can convert to a MPEG2 file or .mpa/.mpv but how to I turn these into the set of files that a DVD likes?
I'm expecting to create vob and ifo based files.
Thanks for any help
Floob.
The benefit of IFOEdit is that it is free too. If you really wanted to be fancy, you could make up a textfile called celltimes.txt an put the frame numbers of where you would like chapters to be created. The only downside to IFOEdit is that you can't create menus.Originally Posted by wulf109
You could use TMPGEnc DVD Author also which will create menus if you like but you would have to manually define chapters.If in doubt, Google it. -
create vob ifo files = DVD AUTHOR,
https://www.videohelp.com/tools?s=2#2
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 11:07 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 10:51 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 17:26 -
How create menu to Vobs ??
By Seasonal in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2007, 15:10
