I have got a dvd that is over 7gigs and want to copy it.
How can i put it onto a regular 4.7 gig disk the easiest way. ive checked and their isnt many extras on it
lee
Did you look in the guides section or the FAQ ? It is the easiest and the quickest way to find the answers you require.
I suggest you try https://www.videohelp.com/dvdbackup, which is located to your left <=====
For the record, i recommend DVDShrink also.If in doubt, Google it. -
When you use dvd shrink, re-athour the dvd and just put the main movie on the new dvdr, take away all the menus and extra, its helps the decrease in picture qulity while also less liekly to become another coaster while burning
DVD region settings are a joke, I can't believe how stupid people are falling for it -
i need to keep the menus as i have got diff episodes on one disk and so needed 2 b selectable
Use DVDShrink and do a full disc copy. Look at www.dvdshrink.info to find out how to use.
Just a quick question, did you even look at any of the forum posts. This question is asked at least once a week, probably more.Blah, blah, blah
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
Any s/w to reduce audio dynamic range in DVD files WITHOUT demuxing first?
By EmmB in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2011, 16:22 -
Is there any way to reduce the size of subtitle fonts on an existing DVD?
By DeathStalker77 in forum SubtitleReplies: 4Last Post: 25th Jul 2011, 17:35 -
Is it ok to reduce dd true hd to 16 bits for dvd mode ac3 in eac3to? yes
By yoda313 in forum AudioReplies: 0Last Post: 22nd May 2010, 19:44 -
how to reduce flickering ?
By logicom in forum Video ConversionReplies: 3Last Post: 20th Oct 2008, 14:15
