i have an XD DV290 aiwa, stand alone player and it only plays certain dvd i live in the UK can you help
siven![]()
Results 1 to 14 of 14
@teegee
thx a friend gave me a dvd c - - -
it is not playing i have tried to change the zones but it want play
siven -
Please be a lot more specific.
Is the disc a commercially pressed disc (you bought it) ? If so, what region is it ? What region are you in at the moment ?
or is it a burnt copy ? If so, what program was it burnt with ? What discs are you using (manufacturer) ? speed ? +/- ?
We are not mind readers you know.If in doubt, Google it. -
You could always play it on your computer, assuming it has a DVD drive.
@jimmalinko and all
thx zone 2 for newcasle england uk,
the dvd was burnt using nero express, they are datawrite red(v2) dvd-r(-) discs
burnt on a +/- burner and i burn them at 4x speed
hope this info helps and sorry i am new to this posting
locnej -
According to the page I linked to, your player only plays DVD+R discs. What you have is a DVD-R disc.
Hi locnej
All the films we buy in stores or rent in the UK are Region 2 , any burned disc or copy doesn't have a region code .
Is it just the one disc that you can't play , those datawrite red are pretty cheap nasty discs , it may just be that your player doesn't like that disc.
Have you got anything else to try the disc on , does your pc have a dvd drive or have you got a ps2.
You often find that the cheap players that Asda and Kwik Save sell for around £30 have more chance of of playing back-ups successfully than the bigger brands of player. -
hello all thanks for your help i have been to asda and bought the player the guy i got the copy from told me the same thing as you say it works no problems here
ta m8ts love the site
locnej
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 15:33 -
By dymx in forum DVD RippingReplies: 1Last Post: 22nd Oct 2007, 12:30
