Hope someone can help me.
I am using memories on tv to create a simple DVD. Spent alot of time on the transitions and Ken Burns effect and the previews look great. However when I go to BURN the DVD it states that it will create a Video_TS folder and AUDIO_TS file. However when I hit burn and check the directory, it makes seperate mv2 and mp2 files however it doesn't make these folders and then the DVD burn software doesn't know what it is looking at because it doesn't have the proper folders. I have tried creating them before the burn process but it just wipes them out.
I am using version 2.1.3
Nero 6 drivers through the program for the BURN part (not that it gets that far)
on a Windows XP machine
Thanks for any suggestions.
Jeff
Try creating your MPEG2 file (I believe there are a few options... create MPEG and Burn and just create MPEG2.)
Once you create your MPEG2 file use your DVD burning proggie dejour to create your masterpiece.
Dear Ole Dad was encountering the same wierdities... I read a few other threads and had him try that... it worked... He uses MovieFactory3
Good Luck
HDCP troubles...
By AKA510 in forum Blu-ray RippingReplies: 7Last Post: 27th Nov 2009, 09:12 -
encodings troubles
By Benjy in forum Blu-ray RippingReplies: 9Last Post: 23rd Oct 2009, 01:22 -
ipod troubles...again!
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 21:52 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 17:55 -
Terrible PC troubles..
By SE14man in forum Newbie / General discussionsReplies: 9Last Post: 29th Sep 2007, 15:04
