Does frame rate causes sync problems with the audio? I followed the guide at
http://www.nanomessiah.com/dvd-backup/ogm-divx
When I add my audio file to the video,and checked at frame rate. I see 2 options,No change (29.970) and change so audio and video durations match(29.938)
Whats wrong? My audio is in sync perfectly with my video but it gradually lose sync. Could it be due to the frame rate instead?
ok,I always wanna know about something in goldwave,if I were to cut a part of the audio,it will be e.g 28:56.75134 but in vdub and other programs,the audio is only displayed to 3 decimal places. Do I replace the last 2 places with 00? e.g 28:58:75100 or 28:56.75134 keep the 2 places?
One last thing,can I convert with audio in DVD2AVI?
https://www.videohelp.com/forum/viewtopic.php?t=221896
I followed that guide there,but is it possible to do it with audio?
EDIT: The problem isn't fixed yet,I still get audio desync,is it possible to see the frame rate of the video? See the frame rate for each part of the video like in DVD2AVI where I can see the framerate for each part of the video as its playing.
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 02:32 -
2 videos with different frame rate sync problem
By dgiulian in forum Video ConversionReplies: 1Last Post: 26th Mar 2011, 20:40 -
Video out of Sync, Frame rate question
By jin007 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jul 2008, 13:17 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
