i haev 3 different mpeg files that appear to be in vcd format and i would like to get them all together into one of course avi and then of course onto dvd.
what i am doing is i am extracting the files using the guide and isobuster and then i convert them to avi and then try to merge file 1 and 2 together but it ends up making the file like about 100GB and yes i did say 100GB I tried using huff or sumthing like that. Can someone please maybe give me a little more direction into what i could do a little better as i am sort of lost with some of the guides that i am reading.
Normally i have to mpeg's that i extract using isobuster then i use virtualdub to convert them with no compression and then i append them together. I then use TmpegEnc to get them to 16:9 ratio adn then fianally TMpeg DVD Author to finish up and finally nero to burn. I seem to have no problems with this method except it takes like a day to do this.
Runnin:
Athlon 3200+
512MB RAM
160GB HDD for movie space
Lite-On EXT. DVD Burner - 851s
Results 1 to 19 of 19
Originally Posted by techmaster-1
Your way will only result in quality loss due to the number of conversions, every conversion looses quality.
BTW, time to change your handle..perhaps tech-in-training. Just kidding."Art is making something out of nothing and selling it." - Frank Zappa -
That 160GB HD came in handy then.
Not surprised by that huge file , thats what you call an uncompressed avi file.
Agree with ZippyP .
You can get 7.5 hours approx of vcd mpeg1 on a DVD-R . So as long as your files aren't any longer than that in total you should be ok. -
http://www.digitalfaq.com/convert/vcdtodvd/vcdtodvd.htm
I found this by clicking on the words TMPGenc DVD Author in ZippyP's post and it took me to the TMPGenc DVD Author page.
Scrolled down and it lists the guides available for it.
This does assume that your files are indeed Mpeg1 (VCD spec). -
ok well it is mpeg 1 so i will have to convert it...i will have to look that up on how the quickest and best way to do that is
No , if it is mpeg1 that is a good thing , that means it is vcd and you can use it .
Start TDA and click 'Start new project' Then 'Add file'
Then select your first file , TDA has a box to check to convert the audio sampling rate , create your chapters for that clip.
Then click 'Add New Track' add your next clip create chapters and so on. -
well sort of but at the same time not as the video size is not working it says that the video res. of 480X576 is not a valid dvd format....i swear it must be ment for me to have the worst day possible today...or i should say this week
so then what would be the best way to keep the best quality if i had 2 different files that were the correct format, in order to put both of them together and fit nicely on one dvd
Could you first specify whether you're in a PAL or NTSC country?
NTSC. I guess i am lost as to getting the PAL SVCD converted to NTSC. I have been trying to read and follow some of the guides and maybe i am just reading them to fast the few times i have checked or maybe i am just a little lost as to what i am even trying to do. I think I need sum 1 to slap me around and tell me what i am trying to do as I am now jsut totaly lost. I tried some of the above methods with 2 other SVCD's and i am getting the wrong size again and also GOP to long errors.......someone please save me from myself
You'll probably have to convert the 480x576 25fps video to 352x480 23.976 with pulldown applied. I would imagine that TMPGEnc Plus would be good for this, but I think you should hold off and wait for someone to post that is more knowledgable of PAL-NTSC than myself before you attempt anything. Where's FulciLives when you need him? :P
I'd convert to 25 fps PAL and see if your dvd player can play it. I know my player has no problems with PAL. Try a short test and use an RW. It's alot easier than converting framerates if it works.
Select the PAL DVD template, use the source range function in Other Settings>Advanced to specify a short clip, then author the clip as you normally would. Burn onto a RW disc.
@techmaster-1
You can try to cut small part of a file with TMPG and make a PAL SVCD from the cutted mpeg. BTW if it is mpeg-1 it is non standart SVCD. How you found out the files are mpeg-1?
If this SVCD play in your player there is big probability that the pal dvd will play also.
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 22:10 -
Consider source as XDVD format MPEG file?
By headless chicken in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2010, 20:44 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 04:14
