Has anyone heard about a firmware crack for this drive for bit setting? I really would hate to buy another dvd-burn just for dvd+r's. This will probably be the last plextor drive that I buy until they get there act together on the bit-setting and dual layer issues.![]()
Perhaps if you did some homework before you bought the Plextor drive you would have found out that there is NO HACK FOR BITSETTING CAPABILITY & AS FAR AS DUAL LAYER IS CONCERNED, DUAL LAYER MEDIA won't be available till the end of June. Don't blame Plextor for your failure of not checking out what is capable of the drive. Geez!This will probably be the last plextor drive that I buy until they get there act together on the bit-setting and dual layer issues
There is no hack for the Plextor 708A drive. You want bitsetting then purchase a LITEON drive. LITEON has a official utility to use BITSETTING. Or you can get a NEC drive that uses a hack for BITSETTING. In my opinion the Plextor 708A has better writing quality than the LITEON drive. I can burn the same movie with both the LITEON & PLEXTOR drive. The LITEON burned disc has a tendency of not being able to playback in certain standalone dvd players. The PLEXTOR burned disc will play in all of my standalone dvd players. I have more problems with the LITEON burned disc. Remember that's my opinion.
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 19:15 -
LG LRH-780 harddrive upgrade
By canadian bacon in forum DVD & Blu-ray RecordersReplies: 44Last Post: 24th Oct 2009, 03:03 -
remove H.264 for MVIX 780
By octorfish in forum ffmpegX general discussionReplies: 1Last Post: 5th Sep 2008, 12:42 -
Recording Times with the LG LRH-780
By Battisti in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Nov 2007, 00:13
