I want to record to either -RW or -RAM and then take the disk to my PC and edit the video (mainly trimming the commercials) and burn to -R
I do not plan on sharing the disks, but I may decide to keep the disk with commericals and all.
Would either media suffice?
Thanks.
Results 1 to 10 of 10
RAM will require a drive capable of reading a RAM disc. RW should play back fine in any drive. RAM is more versatile and a longer lasting format as far as rewritability goes, but not many DVD drives will read them. If you have a toshiba or Lite-on DVD-ROM your drive may be able to play them back. Check to see if you drive supports it before even considering RAM.
Thanks.
Leaving aside the issue of finding drives that will read DVD-RAM, I want to know whether there is anything fundamentally different in editing a DVD-RAM versus a DVD-RW on a PC drive. -
Editing on the PC will be virtually the same. Both formats use .vro files (packet written in DVD-VR mode). -RW has the added benefit of being able to record in DVD-Video mode.
The issue of -RAM vs. -RW media? RAM is advertized to go up to 100,000 re-writes. -RW 1,000 re-writes. Personally, unless the RAM is in cartridge form, I sincerely doubt it could last more than 1000 re-writes before it's all scratched up an unusable anyway. I am very careful with my media, and I am only up to probably 50 re-writes with my media. I doubt I would re-write any media even 1000 times.
TJDLDW 5001, Nov 2003. Pioneer DVR-220-s, May 2004. Haup PVR-250 (2) Ver. 15 + 16. Slowpoke P4 1.8Ghz, 500 gig . Dish DVR-510 - 100 hrs. DirecTV RCA. DLP HD HT Projector at 170 Inches Diag. Tivo Gen. 1 with 180 hours -
Excuse me for slightly off topic - Lordsmurf said editing Ram and -RW is easier compared with +RW. I don't have experiences with -RW or Ram with DVD capturing and editing. What do you think?Originally Posted by tjdmobile
I have been capturing with DVD recorder using DVD+RW or DVD+R media which records them in .vob files. Cropping or deleting unwanted scenes on PC is extremely easy with DVD shrink. Picture quality is good with 2 hour mode when the source is DV, or Hi8 or S-VHS, or LD or DVD and acceptable with 4 hour mode when the source is tape, on my 32" TV. I am only concerned with the contents not fancy menus. In my situation, I don't see recording or editing problem and maybe easier than using -RW DVD recorders. Correct me if I am wrong.Sam Ontario -
Depends on the recorder. My +RW recorder (LiteOn 5001) disks are invalid when I load them in DVD shrink. I am going to look into using DVD shrink to edit my -RW (VIDEO-Mode) disks.
RW and RAM are easier because they use packet written data. This effectively turns these disks into low-capacity hard drives. When you make an edit, it's instant, and the space is reclaimed (even if the edit is in the middle of the cap). With +VR, space is reclaimed, but in a linear fashion like video tape. If you free a half hour at the beginning, you can't insert a 1 hour show there, as it will overwrite files further along. -RW and RAM again don't have this issue.
I think LordSmurf would have also been referring to on-disk editing being easier. In my case, edits of -RW are almost as fast as doing edits on the hard drive. Cuts in DVD-Movie factory also do not get re-encoded on -RW as the do in +VR.
Just my opinion.
Thanks for the info. and your opinion.
You should try latest version 3.1.7 if you had not done so.Originally Posted by tjdmobileSam Ontario -
If you have a LG DVD burner DVD-RAM is better. you can get one at www.newegg.com
+RW is best for PC editing (no finalize needed). +RW alter the IFO files badly when editing on those recorders (does NOT apply to editing on PC). Never found a recorder that did a good editing job.
-RW is 2nd best when using DVD-Video mode (but may need 3-15 minute finalize) ... just as easy to edit on a PC, and editing on the recorder yields decent results. -RW VRO sucks, VRO is not the easiest file to mess with (unable to decrypt by IFO which I prefer)
-RAM is VRO only. As above, VRO sucks. Add that to difficulty of getting the disc to load, and you'll hate it as much as me. (Plus a lot of ROM drives see RAM but won't load the files, forcing you to use ISO Buster or other UDF reader software). But it's the most perfect on-recorder editing solution, as the discs are durable and like optical hard drives.Want my help? Ask here! (not via PM!)
Lordsmurf,
How do you compare the picture quality of 4 hour modes of your APEX or LiteOn LVW5001 with your JVC M10? See I am not a perfectionist, if there will be no noticeable difference on my 32" TV, I will stay with my +RW recorder, no upgrade (or downgrade) with -RW.Sam Ontario
Confused about Levels
By Smells_Like_Feet in forum RestorationReplies: 2Last Post: 4th Mar 2012, 08:51 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused with RAM memory types
By alegator in forum ComputerReplies: 2Last Post: 18th Apr 2010, 18:56 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 08:51
